Error message on Quit
https://forum.reallusion.com/Topic372965.aspx
Print Topic | Close Window
By HowardV - 8 Years Ago
Everytime I Quit CTA3 (P/L) I get an error message telling me Crazytalk Animator has unexpectedly Quit. Not really a problem - but a bit weird.
By rolandhere - 8 Years Ago
I have the same problem as well, including a few other issues. I'm using Pipeline, latest 3.3 update.
One obvious reason seems to be the absence of a "close" dialog in the file menu. In short, I cannot actually close a file as I would in any other program. All I can do is save the project and quit.
Which is a problem because today I started getting a "project save error" on the file I'm working on, so I can't save it anymore. But that's another issue..
CTA3 still has some fixin' to do, it would seem.
BTW. I'm using CTA3 Pipeline on a MAC Pro Tower (5.1) running Sierra. (10.12.6).
By Peter (RL) - 8 Years Ago
Hi... I can't reproduce the problem under Windows 10. Can you let us know which operating system you are both using. Thanks.
By Rogue Anime - 8 Years Ago
Hello Peter - I have Windows 7 & I too get this error in Carazytalk now - ALSO - I'll save the project, and when I go to close it right after, it asks if I "want to save the project"! So I do that, and it keeps doing the same thing - ALSO - it won't open several projects I was working on just a few weeks ago - There is some kind of bug I haven't had before this year, if that helps.  ~V~
Rogue Anime (7/9/2018)
Thanks for confirming your OS. There is a known issue with Windows 7 that can cause this shutdown error. I will check the status of this issue with the dev team but sadly as Windows 7 is now reaching end of life and Microsoft support is stopping, it may not be fixed sadly. You will find the problem does not occur with Windows 10.
For the project opening issues, please can you let us have one of the problem projects so we can test it. You can send a download link to Support or PM a link to me if you prefer and we will take a look. You can use Dropbox, Google Drive, OneDrive etc. to make the link available to us. Thanks.
I just updated my post, which then promptly disappeared so that it could re-approved, no doubt. :p
I just wanted to add some of my specs. I'm using the Mac version of CTA 3 Pipeline on a 5.1 Tower running Sierra. (10.12.6).
rolandhere (7/9/2018)
Thanks for supplying more information.
For the project save error I would advise contacting our Technical Support department using the link below. They will be able to help you with this.
By tomcleland - 7 Years Ago
I have had the same problem using macOS Mojave 10.14.5. Also sometimes get stuck booting the iMac but that may be a separate issue.
"CrazyTalkAnimator3Pro quit unexpectedly."
