Change color of wireframe?
https://forum.reallusion.com/Topic372783.aspx
Print Topic | Close Window
By gordryd - 7 Years Ago
Hi, I want to do an animation where some of the props are wireframe.  Looks like it is defaulting to white for this -- does anyone know how to change the wireframe color?  Thanks...
By Skuzzlebutt - 7 Years Ago
you can use the fog
in certain circumstaces
set near 1 and far 20 or so
this example shows it gradient to red.  near:20 - far:1000
Kipster, thanks for the reply.  I'm afraid this would make everything past a certain 'depth' red (in this case).  Apparently it is not possible to change the wireframe color -- any experts out there to disprove this?
you could make this work a few different ways
without any external app
but, lets see if the "experts" you speak of can answer this...
By 4u2ges - 7 Years Ago
I am no expert :). But first what comes to mind is to make an opacity map out of UV map. And then simply use any diffuse color.
Here is an iClone ball with opacity map made from iClone base UV map (512x512). For more precision/resolution it can be up-scaled and tweaked in Photoshop or similar...
https://forum.reallusion.com/uploads/images/f05f8918-f116-4aab-aee9-f712.jpg
and here's one with customized for better resolution opacity map:
https://forum.reallusion.com/uploads/images/69129e7d-44ae-448d-88c8-9ce4.jpg
