CTA3 crashing when rendering video. (Works in 32-bit mode)
https://forum.reallusion.com/Topic371903.aspx
Print Topic | Close Window
By RikiFou - 7 Years Ago
My CrazyTalk suddenly stopped rendering video. This was with the previous build. Suspecting a corrupted file, I tried several different projects... no success. I then saw 3.3.3007.1 is available. I've now installed it and it still crashes immediately exporting MP4. I tried again with AVI, chose uncompressed, and it made it to frame 2 before crashing. This version displayed an error message the previous did not:
https://forum.reallusion.com/uploads/images/ce0c11bd-12a6-4bc2-b195-5bb4.png
The instruction and memory location appear to be different each time. When I came here to ask for help I discovered the pinned message about Windows crashes. I launched the 32-bit version from the bin folder. The AVI then worked (4G for 00:23!). I had to re-activate MP4 codec, but it then rendered completely.
So I found a workaround to my immediate problem, but I don't think it's a solution. (I do plan on running FFMPEG on that 4G AVI to what kind of quality variations I can get!)
By Peter (RL) - 7 Years Ago
Have you tried uninstalling CTA3 completely and then re-install the latest full version again?
You can download the latest full version from the Reallusion Hub or your Member Account > Registration page.
It would also be wise to run Windows Update to make sure your system is updated and also update your graphics drivers in case that it the problem.
