By sonic7 - 6 Years Ago
There's a Boris FX plugin called 'glint' which has a great look when it's added to iClone 'lights' - in post. (gives you a 'starburst' sort of look) Problem is ... how to obtain this Open-FX plug-in for Vegas Movie Studio ... The great thing about it is, -- as you 'move' the camera, the glint 'changes' (interacts) so it adds a 'live', 'dynamic' feel to your video. My recent purchase of 'Vegas Movie Studio' (by MAGIX), has a stripped down version of 'Boris Continuum' - but only a very few of these FX are actually 'free'. The vast majority, including the 'glint' effect are only available (as far as I know), by purchasing the 'full' (multi-hundred $) version of Boris. So I'm trying to figure a way to get the 'look' of this 'glint'. Would anyone have any ideas or suggestions? ..... thnx.
By raxel_67 - 6 Years Ago
That looks like flares you could create using the hdr feature in the visual tab
Can't remember if I tried that Raxel.... I'll give it a try .... thanks
By illusionLAB - 6 Years Ago
Fusion...
Hi Mark ..... Yes - Fusion was the very 1st thought that came to mind .... I had a look at Fusion's 'tools' list, and did some googling for a 'Fusion method' to achieve this, but didn't get anywhere. The Boris 'glint' settings allow you to select the 'threshold point' (or level) at where the 'glint highlights' are to appear. The number of 'glint counts' (star branches) can be selected, and you can scale the 'size', plus alter the 'width' of the branches. Probably best to 'explain' with pictures ....
Actually - to get the result above, I found I needed to 'isolate' the highlights first. I did that in Fusion with the following 'wiring' lol , - my 1st Fusion project ! (see pic below). I then imported this alpha png sequence (it's a moving camera) into Vegas Movie Studio as another 'layer' directly 'above' it's original, (but 'under' the avatar track of course). It was this layer I applied the glint to. - Seemed to give a sharper, more defined result, - because using glint on the original layer of these lights, gave in a 'blurry' and less defined look. Plus it added unwanted glint to the 'body' (casing) of the lights, so looked 'unnatural'....
Edit: So apart from the 'how to' of producing a glint effect, something else has occurred to me..... If you create a scene with both: ●1. 'glint' (for a 'star burst' look) and, ●2. 'De-focus' (for a 'dof Bokeh' look).... then which should come first in your 'order' of FX? #A Do you apply a glint and then de-focus? #B Do you de-focus first and then apply the glint? So which way around would it occur in the 'real world'?
Great to see you're "having a go" with Fusion - your idea to hone in on the brightness with a luma keyer is proof you 'get it' more than you may think! The "glint" effect in Fusion is called "hilight". It doesn't offer as many features (in the one plugin) as Boris does, but has the necessary "threshold" and "point count" parameters. Remember, easy way to find nodes is to hold down "ctrl+spacebar" to open search. Also, you pointed out a problem that all "threshold" based effects have in common - glows or glints appearing on 'bright things' in the scene that you don't want... this is where the power of "masking" comes in - not surprisingly, Fusion's masking is as good as it gets!
Thanks Mark .... As you've no doubt discerned, I'm using the *familiar territory* of a Vegas style NLE in combination with the new and exciting 'Node' approach of Fusion (new for me at least). This alleviates the 'either'-'or' dilemma of 'choosing' which one to go with. I can be at home (productive) with 'layers', and still experiment with Fusion's 'nodes', (exporting the results across to Vegas). It's a perfect solution really - especially given that Fusion is totally 'free'. So now I'll play around with 'hilight' in fusion .... thnx for the heads up on that Mark ...
