iClone Character Creator v1.5 Trial Content Setup error
https://forum.reallusion.com/Topic370502.aspx
Print Topic | Close Window
By Aspigame - 8 Years Ago
Hello,
I am testing Character Creator Lite and I am trying to install the Trial Content, but it fails with the following error:
https://forum.reallusion.com/uploads/images/07230dee-0641-4ba2-92a0-8d42.jpg
Character Creator v2.3 Lite is installed in "C:\Program Files\Reallusion\Character Creator 2 for iClone\Bin64\CharacterCreator.exe"
However, I've set the template directory to "F:\Reallusion\Template\Character Creator 2 for iClone Template".
Could this be the reason of this problem?
By Peter (RL) - 8 Years Ago
Hi...
Apologies for the inconvenience. There does indeed appear to be an issue which I will try to get rectified as quickly as possible. As soon as I know more I will update here again.
UPDATE: The trial content has been repacked and should install properly now. :)
I've downloded the new file and I get the same error.
I'm so sorry to hear the problem continues. Something must have gone wrong during the repacking process.
I will check with the content team again to see what's going on. Please do accept our apologies for this further delay.
UPDATE: Please can you try downloading the trial content again from the page below and ensure the downloaded file is called Character_Creator_2_Trial_Content.exe
https://www.reallusion.com/character-creator/solutions.html#trial-content
You should then find it will install correctly into Character Creator 2.3 Lite. :)
Yes, this one is working.
Thank you.
