From Maya to CC
https://forum.reallusion.com/Topic370218.aspx
Print Topic | Close Window
By jason.delatorre - 8 Years Ago
Ok, interesting challenge. I have a character that was created completely in Maya (and Zbrush) that I would like to continue to edit in Character Creator. Obviously I can save it to FBX 2012 as been well documented but I don’t have a key since this wasn’t orginally generated from CC2.
Is it possible to get it in there or is 3d exchange the only option?
Is there a way I can export a cc2 character, then use it’s key to import my guy?
By Kelleytoons - 8 Years Ago
You cannot make a character into a CC avatar -- it can only start that way and be edited further.  Any other attempt won't match (verts).
So you can bring it in as a non-standard avatar, via XChange.  But you won't be able to do anything with it in CC.
Bummer! I had a feeling that was the case but I was hoping there was some super secret trick I wasn't privy to. Thanks, Kelleytoons! Appreciate the response.
