how to make particle effect move along a path?
https://forum.reallusion.com/Topic367833.aspx
Print Topic | Close Window
By Famekrafts - 7 Years Ago
I am trying to make particle effect follow a path, say a helix, the problem is nothing is happening. Do I need to keyframe it on each path block?
Well, I managed it. by setting two keyframe points between the path.:)
By wires - 7 Years Ago
No need to play around with adding keyframes.
Add a path to the scene, select the Particle and in the Modify panel click on "Pick Path" and then on the Path in the scene.
https://forum.reallusion.com/uploads/images/61f3f114-56ad-4e9d-87bc-3b2d.png
Next scrub along the Timeline to the point where you wish to have the Particle complete the Path route. In the "Position" field enter 100.
https://forum.reallusion.com/uploads/images/4999dc85-9d97-4898-9cee-ff2b.png
The Particle will now follow the Path for the time duration selected.
If you want the Particle to move faster then move the last keyframe to the left on the Timeline. Moving the last keyframe to the right will make the Particle move slower.
https://forum.reallusion.com/uploads/images/56a11515-2956-477d-bd54-b442.png
