Render Issue Iclone, who can help?
https://forum.reallusion.com/Topic366779.aspx
Print Topic | Close Window
By sbaerman - 8 Years Ago
:)https://forum.reallusion.com/uploads/images/c6dd20e5-e380-486b-b198-a739.png
Hi all,
i have a tricky question on Rendering :
- if you see the Image, above the eye, there is a squarish field on the reflection of the ball. When Rendering Video, the squarish field Shows up everywhere, it Looks like boxes of a bady rendered codec, but it is not the codec. Also jpg have the issue. I tried all Settings, so i do not know, where the issue is? Who can help?
By Kelleytoons - 8 Years Ago
Okay, based on Tony's experience we now have to always ask this -- what OS?
(If you aren't running Windows 10 with DirectX 12 that could be the whole problem right there).
By Rockoloco666 - 8 Years Ago
Also a screenshot of the materials in the eye would be useful
So I have re-rendered it !
Image 1 : Screenshot from the tool directly = no issues
Image 2 : Rendered Image = quality impact : see the small squares in the reflection !
Am using windows 10. But where is the issue? I have set all rendering settings to maximum. Why is the preview better than the final results?
https://forum.reallusion.com/uploads/images/fc6360b4-793b-4ad1-a247-1bf7.jpg
https://forum.reallusion.com/uploads/images/6124254c-d2ac-4f9d-8f1f-b2b8.png
Here I have circled the issues : squares in the reflection.....
Who knows, what is the issue?https://forum.reallusion.com/uploads/images/156626c8-0c98-4fbf-a713-fb84.jpg
By Rampa - 8 Years Ago
If your using the super sampling, try turning it off.
thanks Rampa, that did do the trick !
... sorry me again. Switching off supersampling did make it a big better, but make it worse also :
see Pictures the renderer makes it worse, that it appaers on Screen - so still looking for help :
to make it clear i have highlighted it underlined in red -https://forum.reallusion.com/uploads/images/67dbe613-a942-44ed-ad96-5639.jpghttps://forum.reallusion.com/uploads/images/6c251ed6-52c0-4ca8-84cc-a7d6.jpg
https://forum.reallusion.com/uploads/images/6a2b6173-0e12-43c1-acc8-12fb.png
