How do I change the position of where the mouth opens?
https://forum.reallusion.com/Topic362614.aspx
Print Topic | Close Window
By Data Juggler - 7 Years Ago
I created my first talking character (in about a half a dozen attempts), and I got pretty close to what I want.
The only issue I have is the teeth that are visible on the top lip show a little bit of the lip that I need to be transparent.
Is it possible to either set the position of where the mouth divides, or edit the sprite that contains the top lip?
Thanks for any help
https://forum.reallusion.com/uploads/images/c1c9b778-7f64-4c05-9236-1fc1.png
I figured it out. I had to use a different image for one. An image that the divides closer to even horizontally made a difference.
I also found the Face Fitting Editor button and zoomed way in and used magnifier and it helped me see where the split was going to be made.
I making good progress, just lots to learn with this I am sure.
