G3 Animated Props - Weather Maker (2018, 03)
https://forum.reallusion.com/Topic360627.aspx
Print Topic | Close Window
By Miranda (RL) - 7 Years Ago
The Tools for Atmosphere Change!
Product: G3 Animated Props-Weather Maker
What is the weather condition in your animated story? Is it sunny, cloudy, rainy or snowy?  If you need a windy scene, or a romantic autumn breeze with fallen leaves scattering on the street, then this Weather Maker pack is what you need!
G3 Animated Props - Weather Maker is essential for any 2D scene for when you wish to add a touch of weather elements to your animations.  All animated weather and natural phenomenon components can be combined separately or used individually to create weather or celestial events.  Try it! It’s really fun!
Product Includes:
  • 62 Props (35 Weather Components - Sunny, Rainy, Snowing, Cloudy, Lightning, 15 Skies, 15 Shades, 5 Dust & Air, 7 Light & Fog, and exclusive bonus - 7 Combined Weather Effects)
  • 7 Bonuses (Weather Effects)
Compatible Software: CTA: v3.2 or above
5 TYPES OF WEATHER COMPONENTS
https://forum.reallusion.com/uploads/images/4ad88182-9dce-4eab-a49d-2b87.jpg
https://forum.reallusion.com/uploads/images/0a99ca72-d536-4cfe-b041-a6e3.jpg
https://forum.reallusion.com/uploads/images/c73672c5-8e2f-482c-a6d3-aaa2.jpg
https://forum.reallusion.com/uploads/images/9c83f55c-7549-4884-a7af-ecbc.jpg
USE SKY AND SHADES TO ALTER THE TIME AND MOODS
https://forum.reallusion.com/uploads/images/73b11b7f-1450-4e13-8208-0fe2.jpg
DRAG & DROP ANIMATED WEATHER EFFECTS
Visit the PRODUCT PAGE to check full information.
By sarahchips - 7 Years Ago
i have just bought this and whatever i put the effects on my iMac crashes.  Is there anything i can do because i was really excited about using this.  My iMac is only 4 years old and is running on high sierra any help anyone can give me will be greatly appreciated.
By Peter (RL) - 7 Years Ago
sarahchips (3/31/2018)
Please can you contact Technical Support using the link below. They will be able to help you with this issue.
By soytinatiu - 7 Years Ago
I recently got weather creator for CTA3. I'm quite happy with it as it has some nice effects that save me time. I need some help though on a couple of things. First and foremost:
1) It mentions you can make smooth transitions from night to day, light to dark, etc as well shown towards the middle of the promotional video at 1:26 to be precise: https://www.youtube.com/watch?time_continue=3&v=y0JA_A1kelY
How would I go about doing what it shown in the middle of the video to make such transitions?
2) In this video you can see a rainy or snowy icon being dropped on the scene and clouds, rain and a gloomy background appear. https://www.youtube.com/watch?time_continue=13&v=sL0uLZ1qrZk
If such a function exists I'd love to know about it, though I assume that was used just to keep the video shorter, and that you drag and drop a) the cloudy sky, b) the gloomy background and c) the rain, which isn't that complicated.... There isn't a fancy function button that pops everything you need for a cloudy rainy lightningy day etc is there? The rainy icon dropping on the scene where clouds and rain and gloomy i.e. multiple features appear simultaneously is just symbolic not an actual function, right? (Yes, I know you can drag and drop clouds, rain and gloomy background individually, but if there's a rainy or snowy day icon around that will enter both simultaneously I'd like to know.
By sjonesdc - 7 Years Ago
soytinatiu (4/22/2018)
I haven't played around with this pack yet and After watching the video,  I would assume that it is a hide and show/fade out and fade in process along the timeline.  After inital posting I did play around a little bit, and put together a quick example (it's not perfect), using transformation along the X axis of the dark and white clouds, fade out of the dark clouds, fade in of the Godrays.  Hope this helps!
I forgot to mention, that the Dark Clouds, Raindrops and GodRays have actions attached to them,  Select the item, right click, select Action menu, and the list of actions for that particular item is listed.
Thanks! The fade in and fade out make sense. I'll try that out. Thanks for taking the time to help. That should help quite a bit I believe:)
(If I make anything cool I'll try to post it with an explanation in case anyone else finds this as useful as I am.)
By vepop - 7 Years Ago
I downloaded this with some other effects using vouchers.
But after it was downloaded, the folder showed 0 bytes.
The reason given is "The reason is "Failed to connect to web service". The same goes for other downloads.https://forum.reallusion.com/uploads/images/d9e78b69-8a8f-4aa8-8a43-d13b.jpg
Hi Vepop
Sorry to hear you are having problems downloading your content.
Please do ensure you have the latest version of the Content Downloader and try again. This may well resolve the problem.
If you continue to have the same issue, please contact Technical Support who will help you get this problem resolved.
Problem solved. I reset the pc to factory setting and re-install everything back.
Thanks.
