Cannot find a uninstall ....
https://forum.reallusion.com/Topic358449.aspx
Print Topic | Close Window
By davev - 8 Years Ago
I cannot seem to find a uninstall for Iclone 7 creature creator or 3D Exchange - surely I don't have to manually un-install all of this?
By Clark - 8 Years Ago
You should be able to uninstall those programs using Windows uninstall in setttings.
@ Clark - they do not show up in the Un-Install. typically you can right click the .exe ( or shortcut ) in start menu and click uninstall which takes you to the same un-install list as "settings" does - not any of reallusion products show up. they also do not show up in the ccleaner uninstall list. Hence my question....
This is why MOST programs create a un-installer - I do not think Reallusion products do this.... Which does not surprise me... Also if you run setup again it does not ever prompt you to do a un-install....
OK, I manually un installed all the Reallusion   FILES  - I am so dis-appointed I spent money on this DAM program. .....
By pruiz - 8 Years Ago
[quote][/quote]@ Clark - they do not show up in the Un-Install. typically you can right click the .exe ( or shortcut ) in start menu and click uninstall which takes you to the same un-install list as "settings" does - not any of reallusion products show up. they also do not show up in the ccleaner uninstall list. Hence my question....
OK, I manually un installed all the Reallusion   CRA*  - I am so dis-appointed I spent money on this POS program.
This is a competitor harassment issue. We should not even give it the light of day.
By sjonesdc - 8 Years Ago
If you're using Windows 10, it's listed in Apps & Features and you can uninstall it that way or find it listed in  "All Apps" in the iClone 7 folder, open the folder, right click and select uninstall in the "small" dropdown window.
davidcaputokeene, know I shouldn't answer but wanted to leave this informtion just in case a newbie reads this!
Wonder how long it took him (did he clean out the registry too)?:ermm:
@davidcaputokeene
No, david - Just a very un happy person that purchased IClone 7
By wires - 8 Years Ago
Your system must be seriously messed up.
Here are the uninstall options under Windows Settings:
https://forum.reallusion.com/uploads/images/d3795650-9335-4517-9346-79a5.png
And under CCleaner:
https://forum.reallusion.com/uploads/images/91dab449-0b3b-4a32-b0cc-2a83.png
Maybe you should have someone with knowledge of Windows take a look at your PC.
..These comments were deleted and added to a new post -  as a fresh start.~Dave
