iClone 7.2 - 4K Monitor Support?
https://forum.reallusion.com/Topic357929.aspx
Print Topic | Close Window
By Firepro - 8 Years Ago
I've downloaded the trial of iClone 7.2 which is suppose to now support 4K monitors, but I don't see any settings specific to this.  Where would I find them?  Thanks!
By nono78b - 8 Years Ago
Hello.   I have the same problem with 4K Screen. All the menu is very small and there is any configuration in tre product to solve it.
By Peter (RL) - 8 Years Ago
bdezan (3/22/2018)
Try going into Preferences (CTRL+P) and set the Icon and Font size to the largest of the three sizes available. This should be fine for 4K screens.
You may also have to change a Compatibility Setting (found by right clicking the desktop icon for IC7 and choosing properties), put a check in the box to "Override high DPI scaling behavior. Scaling performed by:  Application".
By scleal - 8 Years Ago
Thanks for this info, it worked perfectly, now I can change font size to make UI readable.
