For a better quality in rendering
https://forum.reallusion.com/Topic356939.aspx
Print Topic | Close Window
By guidocornia_20100928110210516 - 8 Years Ago
I need a better quality in rendering the iClone 5 projects. Is there a way?
Maybe using iClone 6 that (i think to remember) is compatible with the 5.
Or something about.
Thank You.
Guido.
By wires - 8 Years Ago
What sort of issues are you having with your iClone 5 renders?
What render format are you using, mpg., avi., image sequence?
What is the output resolution, 1280 x 720, 1980 x 1080?
No matter which version of iClone you are using, the best results can always be obtained by outputting either PNG. Image Sequences, or Uncompressed AVI files. Image sequences do not contain any Audio, while the AVI files have the Audio embedded.
Thank You for the reply.
I render films in AVI, WMV or MP4 format, but the images have too sharpness, and are not fluid as the preview of iClone.
Guido
By Peter (RL) - 8 Years Ago
guidocornia_20100928110210516 (2/11/2018)
Or something about.
Thank You.
Guido.
Hi Guido,
You can open most iClone 5 projects in iClone 7 for improved renders.
Once you have your project in iClone 7, you can use the new advanced lighting and graphical features and even convert your textures to PBR if you wish.
Thank You, Peter.
Happy to read You like at the old good times.
Guido.
