By Roccoz - 8 Years Ago
Hello, so i have started the path to self learning on ICLONE7 and gone through the tuterials online and also youtube, but cannot seem to find any help on scene creation for using the sky tool.
current set-up: so my current way forward is as follows: content: 3d scene: height mesh large: butte: add in sky with clouds i then launch the sky tool and the only thing that can show any movements is on the time scale slider / the other options cannot make any visible changes i have gone into scene set-up to make sure they are not turned off but everything seems fine.
main objectives: outdoor scene to keep it simple to start with so i would like to see the clouds move and also change the sizes for daytime scene night scene i would like to set a scene with the moon and stars showing and moving into the morning scene
are there any walk throughs for setting up the scene in IC7 for begineers
any help and advice would be much appreciated thank you roccoz
By animagic - 8 Years Ago
The sky that you added first is static and probably covers whatever is created by the sky tool. So you should delete the sky and only use the sky tool.
