By william.carey30 - 8 Years Ago
Hello All! Having major iClone problems for the first time in quite a while. Firstly, after years of exporting animations with no problems from iClone 5, I was suddenly getting some sort of error every time I attempted to export an .mp4. They export fine from iClone 7, so I finally deleted iClone 5 and transferred all my projects to iClone 7. When I open them in iClone 7, however, there is another major problem: ALL OF THE SHADOWS ARE GONE. In the thumbnails of the projects, the drop shadows are still there, but not in the projects themselves. I went into "scene manager" then "light", made sure shadow was ticked for the particular light, opened up the modify window, went into shadow settings, and tried darkening the shadow. All this did was darken the shadows on the character (which I have no desire to do). Anyway, my lost drop shadows did not appear at all, which is the major problem. How do I get them back?
Best regards, Bill Carey
By Kelleytoons - 8 Years Ago
Stupid silly question, but what do you have set for display? If you turn display to "High" do you still not see the shadows?
By GOETZIWOOD STUDIOS - 8 Years Ago
Did you checked you actually have a ground that cast shadows after importing that project from an older version ?
"Display" where?
The display settings are (normally) right in the middle of your tool bar -- it has a drop down menu and will either say "Quick Mode" or "High" or "Medium" or "Custom".
Thanks for trying to help! It was on "custom", and I changed it to "high", but my drop shadows didn't reappear. I do have drop shadows on the projects I made in iCone 7.
So when you render it the shadows don't appear either?
You might have to post a project (trimmed down if you want to just the essentials that aren't showing) for folks to help.
I generally just drag in a 2D photo as the background, so, really, the only 3D anything in the project is the character. This was not a problem for the drop shadows in iClone 5. Do I have to bring in a "floor" or something in iClone 7?
grabiller (2/1/2018) Did you checked you actually have a ground that cast shadows after importing that project from an older version ? ..
By toystorylab - 8 Years Ago
william.carey30 (2/1/2018) Do I have to bring in a "floor" or something in iClone 7?
Try this: Go to "Create" ---> "Dummy" ---> "Shadow Catcher Floor"...
Going to try this in a moment, but I think that is the issue, because I just noticed that one of the projects I imported from iClone 5, in which the character is sitting on a bed (prop), does have drop shadows casting onto the bed. I have really never made use of "dummies". Will this render?
Yeah, I think that's the answer, but what a huge pain in the a** to fix my imported animations! I'm going to finish the ones I began in iClone 7, as well as the ones I imported from iClone 5 in which shadows aren't important, then I'll check out the remainder one by one, and probably end up discarding most of them.
By wires - 8 Years Ago
iClone 5 was the last version to offer "Drop Shadows". iClone 7 comes with "Shadow Catcher" Props that can be added to a scene to do something similar as the old Drop Shadow. iClone 7 now only offers the equivalent to the iClone 5 "Self Cast Shadow", but with a lot of improvements. There is more in the Online Manual.
Information on using the Shadow Catcher is in the Manual here.
As I go through the many uncompleted animations I imported from iClone 5, it seems the problem is indeed the fact that "drop shadows" simply don't exist in the current version, as opposed to the problem being lack of a floor surface. I noted the following: 1. One animation did come through with the shadows intact, cast by the character onto the bed upon which she is sitting, but I am thinking this is either a "Wall" shadow, or maybe self-cast shadows from the character can land on a bed? 2. Two animations I made with my character placed in the 3D volcanic (Diablo-looking) scene also came into iClone 7 with no drop shadows, which really makes me think the problem has nothing to do with a floor surface.
By justaviking - 8 Years Ago
In iC5, we had floor and wall drop shadows, which would display a shadow that landed on them, but were otherwise invisible. Normal objects, like a bed or couch, would display shadows, but you would also see the bed.
We lost the drop shadows in iC6.
Now in iC7, you can assign any object to be an invisible shadow catcher (not just planes), meaning you see the shadow but not the object.
If you open an old iC5 project that contained drop shadows, you merely have to add a plane where the floor or wall drop shadow was, and click the box that says it's a shadow catcher. Shouldn't take more than a minute. Add plane... position it... mark as shadow catcher... done.
