PKFX editor Particle IMPORT?
https://forum.reallusion.com/Topic354779.aspx
Print Topic | Close Window
By Alien Maniac - 8 Years Ago
I am wondering if it is possible to import PKFX particle files into IC 7.2 from ther actual Popcorn FX program>not the PKFX IC Plugin?
In Iclone it shows the files as ipkfx. Does That means it is not possible?
One more Q.......
The only PKFX editor I have found in IC 7.2 s the tool adjustments. SO where is it to be found? Guess I am just missing it.
I want to make some new CUSTOM particles.....Not just adjustments to existing particles  .....
Thanks guys!
By hj - 8 Years Ago
hi
It is not a problem to import pkfx from the popcornfx-editor in iClone 7.2.
You have to program the effects in the PopCornFx Editor Editor and equip them with the desired scripts. There are hints which effects do not work in iClone. After the import you can use the Pkfx in iClone and save it as iPkfx and offer it in the Marketplace as your effect.
best
hans jörgen
By propose - 8 Years Ago
Of course, that's what the plugin is all about.  When you start a new project in the editor, you should use the iClone template, create your effect and then import that effect using the pluginhttps://forum.reallusion.com/uploads/images/ed40bf22-c39b-496e-ae2c-d310.jpg
By wires - 8 Years Ago
Space Rider (1/18/2018)
One more Q.......
Thanks guys!
Almost everything you need to know has already been posted in this thread, including a download link for the editor.
Rampa also posted a video tutorial here
