matching hair color
https://forum.reallusion.com/Topic352995.aspx
Print Topic | Close Window
By Elyssa - 8 Years Ago
Hi,
  I want to give several hair styles to one character . So, I tried to match the color of the several hair styles into same tone. I click "modify"-->"material"--> "adjust color" and use the slides. But the result is not satisfied. If you know more accurate way, please let me know.
Thanks.
By Pixtim - 8 Years Ago
Hello,
The problem is that the different haircuts are more or less clear, more or less saturated and different colors at the base. Obtaining exactly the same hue and the same density is difficult.
I think the best way is to open all the textures of the haircuts under photoshop and use the transparency layer to fill them with an identical color. It will be easier to get exactly the same color.
Ogier
Thank you so much!
