Random Character Generator
https://forum.reallusion.com/Topic352792.aspx
Print Topic | Close Window
By TonyDPrime - 8 Years Ago
How cool would this be....
Random character generation.
And -
If you could select from a set of filters to make less random, and from those the generator would generate a random character inclusive of user-chosen bias filters applied.
Would be a very interesting and fun journey to take while using iClone.
Maybe could involve a user tweak-able Python script.
By illusionLAB - 8 Years Ago
Adobe Fuse does this - you can selectively randomize categories... head, torso etc.  It's great for building 'random people' for crowds.
Rampa also mentioned this quickly as a request in an earlier post a couple years back.
Would love to have this feature in CC2 itself, for the characters look much better than the other alternative character generators out there.
The possibilities are immense with CC's available morphs.
Like if you could apply all the morphs first, and then hit a Randomize button, as Rampa had in past suggested, this would be really cool.
My only thing would be to call the "Randomize" button "RANDO", and have it play some kind of ring-tune when you press it.
Music options would be (1) Rambo-like theme, (2) Blade Runner-type dystopian music, or (3) Seinfeld transition music-- pingy slap bass with the synth brass, accompanied by clicks and mouth pop percussion.
By animagic - 8 Years Ago
Would be fun, but without the music...
animagic (1/7/2018)
YEEEESSSSSSSSSS...
a visual option also!
Instead of music, if you want...
So, you press the "RANDO" button and get-
- a GIF of a crowd applauding you, and a certificate appears on the screen, awarding you with "DESIGNER OF THE MILLENNIUM AWARD",
or,
-a Warning Message in red that says, "Character generated - You have 1 hour to use this character is a scene, otherwise the character is subject to random deletion"....
AND....if you don't actually load that character into a scene in 1 hour, it gets deleted.
How about this...
-Your new character is imaged into a 'snapshot' of a "Wanted" Poster...
And that poster says..."WANTED - For being the most AWESOME random character ever generated by RANDO"....
And it shows RANDO - a solid colored character silhouette with a "?" in the middle of the head.
But here would be the best part...
When you then use the newly created avatar in a scene, the aforementioned silhouette character of RANDO surprises you while you use iClone...like RANDO will pop up, randomly, like a "ghost", in a timeline preview for scenes, prior to render...
And then, RANDO will NOT be there upon re-watching the timeline, or if rendered!...
So, it will be like your new avatar is crazy, imagining RANDO is there and then RANDO is actually not there.
PS - do not look into a mirror after midnight and say "RANDO" 3x.
