Assassin_05 is missing body parts
https://forum.reallusion.com/Topic352017.aspx
Print Topic | Close Window
By AncientWire - 9 Years Ago
I wanted to use the body of Assassin_05 for something else, so I pulled off her clothing and found that there is no visible body between her hips and her knees.  I know I can remove parts of a body by masking things out, but there are not any masks in her maps.  This has happened with a couple other characters as well.  One example is when I turned a dwarf into a giant and the boots cut off parts of the leg.
So how is this body masked out without a mask, and is there any way to stop it from doing so?
Thanks!
https://forum.reallusion.com/uploads/images/353de405-7002-4b91-a00d-61b0.jpg
By Galfridus - 9 Years Ago
https://forum.reallusion.com/uploads/images/f23a5a20-9370-4a2c-9315-cc2b.jpg
The mesh isn`t missing. it`s just hidden.
Deselect Hide inner mesh and give it a second or two to recalculate.
Geoff.
Edit: This is in IC7.
In CC2 you can use "unhide" button when in the mesh edit mode.
Wonderful!
Thank you so much!
By AncientWire - 8 Years Ago
There is a change to the way to do this in Character Creator 3.  Select the Character, Modify, Edit Mesh, Face, Visible - Show All Faces
https://forum.reallusion.com/uploads/images/d3a8136a-8e6c-46be-af29-afb8.jpg
