Lord Ashes (12/13/2017)
Possible Solution:
Instead of having the Content Developer specify the sub-folder to which the content should be installed to, have the Content Developer provide values for the following properties: Short Content Name or Short Pack Name and Vendor Name. In such a case, the content downloader could be modified to provide a selection of the 4 above default options (or 5 default options if you want to support both version of the 4th option: Content/Vendor and Vendor/Content) with the last selection remembered so that it would be the default selection if not changed and then the downloader could construct the destination folder based on the selection. Constructing the destination folder based on the selection and the two content properties (Short Content Name or Vendor Name) should be fairly simple but it would make it so much more friendly to the user.
