By Rampa - 8 Years Ago
Seeing as there are no longer move commands in any of the default Personas, I have made this Persona of only move commands. No additional files need, just drop the AML on your character and righ-click to use the new move commands.
By Ziggy72 - 8 Years Ago
Awesome name :D
By nlprod1 - 8 Years Ago
Thank You!
By ian_11 - 8 Years Ago
Thanks Rampa!
By Cary B - 8 Years Ago
Many thanks!
By oatt - 8 Years Ago
Awesome. Thank You, RAMPA.
There is a drawback to this type of walk, and that is that the speed is set. So if have a different sized character, the speed at which the translation happens will be off. But there is a way to fix that.
The AML can be opened in a text editor and the "Max speed" adjusted for each walk. Most of them are currently set at 100. The runs are faster, and a couple walks are slower. I don't recommend changing anything else. The acceleration and deceleration need to be very high, as these do not use separate motions for that.
Scroll down to find them all. It's pretty quick to adjust for a different-sized character. Save a new file for each significantly different leg-length. Then load them and see how you did.
By 4u2ges - 8 Years Ago
Yes, I have noticed a few of the motions give significant slipping feet. So thanks for the tip about the speed change.
By GrannyJ - 8 Years Ago
Thank was very nice of you, Rampa....
By wires - 8 Years Ago
The Master of Motion strikes again. :) Thank you. :cool:
By toystorylab - 8 Years Ago
T.H.A.N.X.
By rogyru - 8 Years Ago
Takes 1 minute to create a persona from Iclone to 3d xchange and back . Surpised people dont know this
By mark - 8 Years Ago
Super cool Rampa! Thanks!!!:D:D;)
rogyrue (12/4/2017) Takes 1 minute to create a persona from Iclone to 3d xchange and back . Surpised people dont know this
That is a good reminder, and I encourage people to take advantage of it. Unfortunately, it only supports perform commands. There has never been an easy move command creator implemented into 3DXchange.
This walk system still works, but is less suitable in some ways because we can now very character size so much. Back when all the characters were the same size, the translation speed did not need adjusting on a per-character basis.
By VirtualMedia - 8 Years Ago
Thanks for the share rampa..
By animagic - 8 Years Ago
Exactly, Move commands have their own usefulness and are different from Performs.So, thanks, Rampa!
By TonyDPrime - 8 Years Ago
Thanks Rampa!
By CtrlZ - 8 Years Ago
Thanks Rampa!!
By Molecule_Bleu - 8 Years Ago
Thanks!
By JanT - 5 Years Ago
Thank you.
By Rampa - 5 Years Ago
Slight updated version, with a really square name! ;)
The only change is that enabled terrain snapping so you don't need a path to follow the terrain anymore. You can just click somewhere on a terrain to have your character walk there. I had disabled the snapping previously to help with stair climbing smoothness. https://drive.google.com/open?id=1lUAiObTov2Gm-n4ebugXIftJAT_DC8IJ
By Galfridus - 5 Years Ago
Thank you very much for the update Rampa. Geoff.:)
By rosuckmedia - 5 Years Ago
@Rampa, Thanks a lot.:) Best regards rosuckmedia
By diomkal - 5 Years Ago
Thank Rampa!
By toystorylab - 5 Years Ago
Thanx Rampa ;)
By videodv - 5 Years Ago
Thanks Rampa :)
Chris
By Procrastinator - 5 Years Ago
Thank you! And i have just learned how to use persona.
By alemar - 5 Years Ago
many thanks Rampa. Is very usefull!
By mark - 5 Years Ago
EXCELLENT!!!!;)
