Crazytalk 6 Display Problems (Intel Graphics)
https://forum.reallusion.com/Topic34890.aspx
Print Topic | Close Window
By Peter (RL) - 17 Years Ago
Recently, some users of CrazyTalk6 have encountered an avatar disappearance problem. Tests have found that this is occuring for Windows 7 users  whose graphics card is the "Intel Graphics Media Accelerator" series. if you have suffered with this problem, please do the following to try and resolve this issue.
Q. Why does my avatar disappear in Model and Output page?
A. The figure above demonstrates that the avatar cannot be normally displayed in Model, Output page and export results. The problem occurs if your operating system is Windows 7 and your graphics card is "Intel Graphics Media Accelerator" series. The problem is caused by an issue within all Intel Windows 7 drivers. You need to follow the steps below to solve this issue:
1) Download and unzip this file:
http://file.reallusion.com/cs/intel_vagcard.zip
2) Copy intel_vagcard.ini to the following location:
<Your CrazyTalk6 directory>\CT Program\config
Note: “<Your CrazyTalk6 directory>” is the installation folder for CrazyTalk6, which is usually in one of the following directories, depending on your machine's specifications:
e.g.
32 Bit OS:
C:\Program Files\Reallusion\CrazyTalk 6
64 Bit OS:
C:\Program Files (x86)\Reallusion\CrazyTalk 6
3) Overwrite the previous intel_vagcard.ini.
Now try to launch CrazyTalk6 again.
Mick Lin
Technical Support Engineer
Marketing Dept.
By agiles37 - 16 Years Ago
I have tried that and it still isnt working, any other ideas?
By Peter (RL) - 16 Years Ago
If you are still having problems, please contact Technical Support who will be able to help you further to resolve this issue. Please use the link below to request assistance.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx.
By tamdamgood - 16 Years Ago
I am having the same problems with Crazytalk 6 and (Intel Graphics) display problems. I have Window 7 an a Intel Core i5-430 processor with turbo boost technology. I would like to know if Reallusions is working on a fix to resolve this issue? These are the newest processors, and I know, that I will not be alone on this issue. Thank-You Tami
tamdamgood (5/16/2010)
Hi,
If you have tried the suggestion at the top of this thread and you still have problems, please contact Technical Support using the link below. They will be able to advise you further with this issue. Also remember to upgrade your version of Crazytalk to 6.2 if you haven't done this already.
Thanks.
By Video Works of NC Inc - 16 Years Ago
Has anyone found a fix for this issue. I am having the same problem and this software is No good to me if it does not work. Please help me.:w00t:
Stefanie_20090922190219688 (6/7/2010)
If you have Intel graphics and Windows 7 then the fix mentioned above should solve the problem. If it doesn't or you are using a different OS, please contact Technical Support using the link below. They will help you to resolve this issue.
Thanks.
i tried that but i get a message access is denied. I am new to PC and got this system just for the use of crazy talk
Video Works of NC Inc (6/8/2010)
Please use the link I gave above. Support will help you get this resolved as quickly as possible.
Thanks.
By ryann1212 - 16 Years Ago
the download link is not working
By troyjohnson - 16 Years Ago
The link to the zip file to fix problem with Windows 7 does not work.  Please fix.
The link has now been fixed. Apologies for the inconvenience.
Thank you, it is indeed fixed and it took care of my problem.  Thanks again.
By Harb40 - 13 Years Ago
Sorry for the bump but I found this very useful. I had the same problem recently and this thread saved me.
Thanks you.
By nick_20091114045858980 - 13 Years Ago
Same issue and fix does not work
Anyone on windows 7 looks screwed
Nick
