cloth issue
https://forum.reallusion.com/Topic347457.aspx
Print Topic | Close Window
By info_38_14 - 9 Years Ago
hi,
many time i adjust cloth but not clear
can you suggest one solutionhttps://forum.reallusion.com/uploads/images/93e9a9bd-28a6-4301-b2c5-823c.jpg
By vidi - 9 Years Ago
the influence of the mesh to this arm-bone needs adjustments with weight painting.
You have to do that in your rigging software
By Wuv3D - 9 Years Ago
info_38_14 (11/13/2017)
hi,
In Your Rigging Software:
One Way is to:
1. Select the vertices of the (UpperArm Bone) and give them 100% weighting value.
The color turns "Red"
https://forum.reallusion.com/uploads/images/c7e28f1b-a640-47a2-b95f-5c2c.png
2. Select the "Lowerarm Bones" select the vertices and give them 100% weighting.
https://forum.reallusion.com/uploads/images/8e449822-443a-41f3-bbc6-7948.png
The area where 2 bones meet.... UpperArm - LowerArm (ELBOW BENDS)
...select all of the vertices (between these bones)...and assign (EACH BONE) 50% weight value. (The color turns YELLOW)
This is a good starting point for (ALL JOINTS).... to properly "Bend" without the mesh collapsing upon itself.
Hope this helps.:)
