3D Video FX Tutorials
https://forum.reallusion.com/Topic34705.aspx
Print Topic | Close Window
By Visconti - 17 Years Ago
iClone4 Tutorial - Virtual Studioz
This video will demonstrate how simple it is to quickly put together and fine tune a production for Video FX. Also, this tutorial is full of tips for customizing both textures and video textures to create the ideal 3D Virtual Set!
iClone4 Tutorial - Motion Montage
This video will demonstrate how simple it is to quickly put together and fine tune a production with 3D Video FX Motion Montage, which will demonstrate how iClone is a powerful tool to create stunning scenes to enhance any video production houses projects.
By hj - 17 Years Ago
hello
where i get the 3D FX props in your tutorial ??
hans jörgen
By Peter (RL) - 17 Years Ago
Hi Hans,
The packs containing all the props can be found from the links below:
3DFX Virtual Studio
3DFX Motion Montage
Hope this helps. :)
By bmailsjc - 17 Years Ago
They are both exciting content options but there is still the nagging issue of leaning how to get the required chroma key masks. So many seem confused and apparently RL is aware of the need to clear this up yet .... nada. What video editors can be used to produce the needed files?
hello
Can write one, what is so special about a 3d FX Prop ?
What makes a collection of simple boxes and planes so expensive??
Unfortunately, there is no free 3d FX Prop to buy only.
hans jörgen
By stuckon3d - 17 Years Ago
hans jörgen (12/17/2009)
hello
hans jörgen
Hi Hans,
that pack is targeted to videographers, people that dont know too much about 3d and all they want is to drag and drop video files to the project and render away.
Now... is it possible to make them by yourself? yes, but think how long it would take you to make all those projects and props that it comes with. Then divide them in man hours and see if is cheaper to buy them or make them yourself.
Hope this helped,
Stuckon3d
By steve_20090920125629670 - 16 Years Ago
I finished installing Iclone 4 and the virtual set and motion montage add-ons.
When trying to load the preset files for the panel or film strip animations - nothing loads.
I've tried to follow the tutorial ( more a marketing piece than a tutorial)) but cann't follow the very very brief instructions.
there is nothing in the iclone manual that refers to motion montage.
per your tutorial - start with a new project, click 'set', then under - content manager - click
'custom' - then click props -
when I follow that - nothing comes up under props, whereas in the tutorial when you click on props - a list of files come up.
I've also tried loading a project - but nothing comes up in the animation window.
All I want to do is load the preset animations and change the images and videos , then render them out.
thanks for any help you can give.
Steve
By harrydsouza14 - 16 Years Ago
Thats really great!
you guys are doing good....
3D Exterior Architect Rendering
3D Architectural Animation Services
3D Interior Architect Rendering
