By dgoldeng - 9 Years Ago
When I attempt to drag and drop a video into Iclone 6 a red circle appears not allowing me to import my video. Can anyone help me with this. Thanks
By wires - 9 Years Ago
What type of video file is it that you are using? Are you left mouse button dragging, or right mouse button dragging? Does iClone display an error/message window?
By Peter Blood - 9 Years Ago
dgoldeng: :) Also be sure you drop your video on the object 'in screen'. If you drag it to the screen it will highlight the objects on the screen as you pass over them. Wait until the object you want is highlighted and drop your video. You can't drag the video into the 'Diffuse' box directly.
:cool: pete
Its a M2TS file. Image enclosed . Thanks
By Kelleytoons - 9 Years Ago
I suspect there's not a chance in Hell iClone supports that format (try MPG or Quicktime).
By animagic - 9 Years Ago
M2TS is a streaming format used for bluray discs. You should be able to convert it. Try googling "M2TS to MP4" conversion.
Thanks
Thanks
