rgrove (3/5/2008)
I'm still a little confused, Peter. You mention cropping the eyes from my "photo", but I'm not sure
I understand what photo you are referring to. Where would I find a photo of eyes I can use in
CT? Can I just use eyes from any reasonably large photo? I was thinking originally I could use the eyes provided in CT 5.0 and just make adjustments in
Photoshop and import back into CT. How would this work?Hi Ricky,
The "photo" I referred to was any good high resolution photo you may have or find on the net. You should be all set now thanks to Rainman's guide and templates. (Thanks for that Rainman).
I don't find the need for a template in most cases, especially for eyes because all resizing and movement can be done in Crazytalk but anything that makes the process quicker and easier is a good thing, so try it as Rainman has explained to get the hang of it.
If you wanted to edit the eyes that are included in Crazytalk then you could output a high resolution image from Crazytalk and then follow the tutorial for extracting the eyes in the same manner as Rainman has explained.
Good luck.
Pete
