Aligning Mix Moves - Character rotates 180 between two matched clips
https://forum.reallusion.com/Topic344750.aspx
Print Topic | Close Window
By elliespotter - 9 Years Ago
Hi guys,
I am suffering a mental block trying to fix what should be a really easy thing.
Putting some Mix Move clips together but the Character rotates 180 degrees between clips.
Please watch this video to see what my issue is. I know the answer will be really simple when I am told it but right now, I am stuck.
I have tried reset pivot and all sorts of align options to no avail. I don't want to stuff the transition with a bunch of transform keys because that's just messy.
By Rampa - 9 Years Ago
There is a fix for that. It seems kind of goofy, but basically you "pre-rotate" the character before adding the new motion. 3Dtest made a nice tutorial on it.
Thanks Rampa,
I knew it would be simple once I'd got it.
Hopefully this will save other the grief I went through.
BTW - I'd be happy to add your Youtube channel to the description credits if you have one.
By animagic - 9 Years Ago
Thanks, Alex, for bringing this up. I've had iClone since 1.5, but motions still baffle me...:unsure: :blush:
