By SpiderTec - 7 Years Ago
just a FYI if any-one has this issue when i downloaded the demo facial mocap for iclone it worked great except for no record button. so i purchased it, then uninstalled from Iclone and the desktop, then a re-install after a restart the camera was blank or fuzzy and not connecting I had to re-install the "realtek" driver for the camera, after uninstalling, reinstalling, restarting, adding the serial number too many times, and also sending the serial # to Faceware Realtime for Iclone it works fine, I did get BSOD from checking all the drivers connected to the USB hub, but after a quick bios reset it is working fine just too bad i do not see a toungue movement option for this
hope this helps any-one that the camera stops working after purchasing and re-installing
By Kelleytoons - 7 Years Ago
You can get tongue movements by enabling "Record audio as visemes" (or whatever the heck it's called -- it's too early for me to boot everything up) on the iClone plugin-in screen to the upper left of the preview and record buttons. Doing this will treat the audio track as it would if you didn't have facial mocap, but turn off the visemes of the lip and jaw (so only the tongue movements are used). While not perfect (because analysing an audio track isn't the same as doing mocap) it's pretty good and I can't tell the difference, really.
By Peter (RL) - 7 Years Ago
Glad to hear you got it sorted out in the end. The limitation of the trial version is that it won't record but you can preview.
