Why is this happening?
https://forum.reallusion.com/Topic341805.aspx
Print Topic | Close Window
By AasmundSchei - 9 Years Ago
When I activate the Apperance Editor, I loose the PBR shading. Is this a bug or is it supposed to happend?
https://forum.reallusion.com/uploads/images/7b94e6b4-bc3f-49cf-b5bf-fd75.png
Even with the IBL pumped up abit, I dont get the same shadinghttps://forum.reallusion.com/uploads/images/4fe8c6bc-090c-4b29-b04f-171a.png
By Rampa - 9 Years Ago
Make sure you select the PBR Substance from the little box as shown in the picture. Note that each body part can be set. The little flame icon on the button is the Substance icon.
https://forum.reallusion.com/uploads/images/2feca613-c5e5-433f-8bd9-cd8a.jpg
I do that, but I still loose the PBR shading. Im using 2.01.
By wires - 9 Years Ago
Your Screen grabs in the first post don't show the options/settings in the Appearance Editor tab, can you show one please?
https://forum.reallusion.com/uploads/images/b70e3d27-4a7c-4dd5-a917-def0.png
Sure. Heres the lips settings, you see theres a small impact in the corner of the lips but not the full lips as there was before I activated the Apperance Editor.
https://forum.reallusion.com/uploads/images/302c3002-1a85-481c-ab11-0d8b.png
I tried to tweak some more, but I still dont get the same result.
It can look like it have something to do with the metallic and roughness setting:
https://forum.reallusion.com/uploads/images/80d76e01-9d0f-4d3e-9690-faeb.png
Same goes for that other girl:
https://forum.reallusion.com/uploads/images/d9006c3a-53a9-48a5-a074-2f85.png
https://forum.reallusion.com/uploads/images/0d850001-b979-423d-ab08-b8c0.png
By the way, will the PBR materials be carried over to iClone when sending to iClone from CharacterCreator? Sorry for all the bumps, but it would be fun to edit the materials with PBR materials too :)
By justaviking - 9 Years Ago
aasmund22 (9/17/2017)
No.   :(
Perhaps you'd like to add your voice here...
https://www.reallusion.com/FeedBackTracker/Issue/Add-option-to-NOT-flatten-Substances-when-exporting-to-iClone-Currently-always-exports-as-a-simple-texture
Voted :)
