Hi Howard,
It is possible to hide the body of your 3D character. To do this go to Create > Texture Settings on the Menu Bar, then select the Skin_Body material and add a solid black texture to the Opacity channel. I've attached a suitable texture if you need one. It is also possible to get a CT8 3D head out as an OBJ but it would require you also have iClone and 3DXchange Pipeline. You can't do it directly.
For any other requests and improvements to CrazyTalk 8, please use our new Feedback Tracker. The tracker is monitored directly by the relevant departmental teams and you will get feedback from the team there. In addition it allows other users to support your request with the most requested suggestions getting priority. Thanks.
To use the Feedback Tracker, please click the link below.
