Fast way to create scalp mesh?
Home
Content Developer
Content Development
https://forum.reallusion.com/Topic338199.aspx
Print Topic
Close Window
By theorysharp
9 Years Ago
I've been running into a problem when trying to create hair in maya.
If I select the head/scalp and duplicate the mesh it causes all sorts of errors with the hip bone down the road when trying to reimport it. Duplicating causes errors.
This duplicate mesh technique is used in
https://www.youtube.com/watch?v=E7f__LNUviw
to create a scalp for hair.
I plan on using xgen to create hair and they use this same technique (a scalp mesh). Since the Iclone/cc hierarchy bugs from any kind of duplication, what can I do? Manually drawing all the polygon faces on a head mesh takes forever!
By vidi
9 Years Ago
There must be a mistake in your rigging and/or wheight workflow
A scalpmesh is only a mesh like others,
and need to binding to the Character Amatarure and then copy skin .
Actually no big deal.
By dogged2003
9 Years Ago
I received this error message if the scalp was from two or more separate parts.And a map of weights for only one bone.
Remove other weight maps.
