Curve Editor 08: Applications
https://forum.reallusion.com/Topic336522.aspx
Print Topic | Close Window
By Grace (RL) - 9 Years Ago
Bouncing Ball
First and foremost, we must have the ball bounce in place and later have the ball move from the left, up-high to the right, down-low.
First make the ball move in Z axis:
https://forum.reallusion.com/uploads/images/afba9430-4502-4f9f-9ec5-0c62.gif
https://forum.reallusion.com/uploads/images/38e5b65a-3f4b-4677-976e-8af4.jpg
The Z motion combined with the X axis motion:
https://forum.reallusion.com/uploads/images/458348d2-b5ab-4dfc-8fc8-239d.gif
https://forum.reallusion.com/uploads/images/ce8f81c6-ae57-4614-a8a6-8ca4.jpg
XYZ scale animation to simulate squash and stretch:
https://forum.reallusion.com/uploads/images/9023a654-e557-4abc-ac8c-1561.gif
https://forum.reallusion.com/uploads/images/ca029642-4962-40d1-a190-52a5.jpg
Using the axis to simulate rotation:
https://forum.reallusion.com/uploads/images/078f93ad-23eb-4fdc-ac94-9987.gif
https://forum.reallusion.com/uploads/images/baad9ce5-039c-4c33-a172-58f8.jpg
Character Motion - Frame Animation
Using only two motion layer keys and an inbetween curve to create the entire motion.
Example 1 - Before
https://forum.reallusion.com/uploads/images/a09f0128-51dc-46a4-bac9-53b9.gif
https://forum.reallusion.com/uploads/images/b27ddc68-5a5d-4350-a1c7-7cc3.jpg
Example 1 - After
https://forum.reallusion.com/uploads/images/62c4c539-9f20-4c5d-96fb-a22e.gif
https://forum.reallusion.com/uploads/images/9e68c111-c831-4905-95e7-fb08.jpg
https://forum.reallusion.com/uploads/images/6488b3cd-8008-477b-be83-4d83.gif
https://forum.reallusion.com/uploads/images/ed0522b7-86c2-4011-b384-71fe.jpg
Example 2 - Before
https://forum.reallusion.com/uploads/images/a47995e9-8049-4498-a2a0-82a1.gif
https://forum.reallusion.com/uploads/images/cefde2f7-8e03-4108-934c-90be.jpg
Example 2 - After
https://forum.reallusion.com/uploads/images/7d0420fc-edf0-4860-abaa-015d.gif
https://forum.reallusion.com/uploads/images/1e7d3a59-7d66-492f-a1e9-afb4.jpg
Smooth Camera Movement
  • Camera can now be set to Default key tangent for animation. (Default Key Tangent, see here)
  • New and old key comparison
Usage
Linear
Curve
Final Result
Mocap Data Cleaning
Body mocap will often lead to situations of hip and foot sliding along with various abnormal limb jittering.
Fix for the Hip Sliding
  • Sample out the torso keys to linear data and convert to curve data.
  • Use Refine Key to down sample the curve data into a manageable amount of keys.
  • Use the Curve Editor and the Transformation Gizmo to inspect the abnormal sliding and direction.
  • Use the Scale tool in the Curve Editor to fix the sliding issue.
Fix for the Foot Sliding
  • iClone Reach Target can be seen as a type of Lite IK effector, thereby, just attach two spheres to the ankles and use the IK Constraint.
  • Use the Lite IK effector to fix the sliding in the steps.
  • Review and compare the final result with the original movements.
Exaggeration
Adjust motion layer keys and in-between curves to exaggerate the motion.
PREVIOUS: 07 - Curve Presets
By bdpbiz777 - 7 Years Ago
Thanks! An excellent solution!
