By pinguintje - 7 Years Ago
As promised a little clip with the Cartoon Masters.
Have fun. Best Regards, Arie
By stuckon3d - 7 Years Ago
Well done! The layout, feel, everything works great! If I had to comment on anything, it would be to make the grass on the ground a little less photoreal. Maybe posterize the texture to make it feel more cartoony? Other than that... fantastic work!
Cheers,
Stuckon3d
By txon - 7 Years Ago
fantastic work!
@stuckon3d Thank you very much. In the picture below I have used a more cartoony grass. And yes....... it looks much better.
@txon Many thanks. And I have a question for you.( in Carga de Caballeros)
Best Regards, Arie
Love it! one more suggestion if I may, you can clearly see a tile pattern on the grass now, try using a blend map with less tile repetitions to break the pattern. If you never done that and need help let me know. I'll be glad to show you how. Awesome work!
Thanks again, stuckon3d.
Here is another picture. For the grass I have used a new Diffuse texture with less tile repetitions and also a Blend texture. (Blend02). The tile pattern is now almost away. Is this what you mean?
But keep in mind the visual settings for this project: - Atmosphere= Toon Shader, Line Art, Edge Width.2 - LUT Film Style 2: 80% All the colours differ from a "normal" project.
Your help is very welcome.
Best Regards, Arie
