Iclone 7 trial crash
https://forum.reallusion.com/Topic332446.aspx
Print Topic | Close Window
By bouncer - 9 Years Ago
hi am trying iclone 7 but it crashes on opening.
A message appears -"color depth and resolution are not compatible
please set color depth to 32 bits and resolution to 1024x720"
then the app crashes without opening.
my system is- Windows 7 x64
                        Ram-24gb
                        cpu-Intel i7
                         graphics-Radeon R9 270x 2Gb
                         screen resolution-1920x1080 32bit true color
                          100GB free space
cant figure it out tried changing resolution but still same message and crash....
Sorry guys I have just figured out the problem
I had "Make text bigger" set within windows so I changed it to "Make text smaller" and that solved the problem iclone opens and works now
By Peter (RL) - 9 Years Ago
Thanks for updating your post with the solution you found. This may help others experiencing the same problem. :)
By tanibravo911 - 9 Years Ago
My Iclone 7 trial crash on the opening
HP 15-ay103dx
8gb Ram
1TB
intel 620 4gb
Please help
Unfortunately Intel graphics are not supported. You need a dedicated mid to high end graphics card from Nvidia (recommended) or AMD. Please see the system requirements below for a detailed list of supported cards.
https://www.reallusion.com/iclone/download.html#system-requirements
I'm sorry I can't bring you better news.
By softwaresucker - 9 Years Ago
Win 8.1 fresh install with all updates on a quad core Asus mobo.
Also updated drivers for my Nvidia GTX580.
I installed Iclone 7 trial using many methods like admin rights, low and high res, changed install directories.
When I try to launch the program it "stops" without any indication why.
This process of install/uninstall/install again with different options has just wasted my entire night.
So looks like I will not be purchasing any time soon..
