How do you contact support if you are having trouble logging into your account?
https://forum.reallusion.com/Topic331133.aspx
Print Topic | Close Window
By Dragonskunk - 9 Years Ago
Everything is messed up as I am logged into this forum, I can log into the trial of iClone 7, but I can't log in to my account?
both https://www.reallusion.com/ and https://www.reallusion.com/member/#/en/login;rurl=
Don't work. I've tried forgot password many times, it changes for the other logins but still cannot connect to my account.
If you click on need help, it says login to get help.
What is the email for reallsion support for those who are in the situation when they can't login?
By Peter (RL) - 9 Years Ago
If you can login to the forum then you should be able to login to your member account. Have you tried using a different browser as it may just be a browser issue. Also what is the error you receive? Does it say your password is incorrect?
If you can't resolve the problem and need to contact Support you can email the address below or you can create a new basic account and use the Support form linked below to contact support.
support[at]reallusion.com
https://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
It's a problem with changing your email on your account I've been having troubles ever since.
I get "error wrong password" then try another password until get the right one and I get just "error logging in, please try again.
All I want to do at this point is to tell support that I discovered why I kept getting corrupt files that prevent it from loading.
https://forum.reallusion.com/317527/Im-tired-of-playing-Russian-Roulette-with-iClone
We did receive your communication and have replied to you. :)
