how to export/import my CC caracter and newly designed clothes?
https://forum.reallusion.com/Topic329961.aspx
Print Topic | Close Window
By Evey Fawkes - 9 Years Ago
Hi, for some reason, My Iclone 7 doesnt give me ANY export options (not alembic and not FBX).
have Iclone 6, 7, CC and Pipeline pro.  working in Blender and marvellous designer.
want to send nude selfmade avatar to and from blender and Marvellous designer and send him back with clothes, or just his new clothes.
Keep having troubles. pls point me to a good instruction.
Also: if i try to import a cloth that I made into caracter creator (for a avatar I made myself)  it asks for a key. What key should I use for a selfmade avatar, or am I stuck with sending a standard model back and forth?
pls help.... still need a great cape for my V for Vendetta. finally figured out how to make one, now cant import it. (only as an obj. but its WAY to many vertices to be off any use). learning this stuff aint easy   :-)
By animagic - 9 Years Ago
When you say Pipeline Pro, do you mean 3DXchange Pro?
You'll need 3DXchange Pipeline to unlock the export features on iClone. If you HAVE the 3DXchange Pipeline then it should work.
Hi, I have 3dx pro. But it still doesnt work. also: when I try to export obj thru 3dxhange pro that i made myself, it keeps saying "i dont need a licence" but doesnt want to export.
By Peter (RL) - 9 Years Ago
IamAnonymous (6/21/2017)
Do make sure you have uninstalled both the iClone 7 and 3DXchange 7 Early Access versions completely before installing iClone 7 and then 3DXchange 7 Pipeline. If you do that you should find you have the options to export to Alembic and FBX in iClone 7.
I have checked your account and see you have both 3DXchange 7 Pro and 3DXchange 7 Pipeline. Please make sure you are using the Pipeline version.
duh! .....
I was using the PRO version. oh.. great... just had a blonde moment. LOL.
thanks!
By Lord Ashes - 9 Years Ago
I assume that the "Export OBJ | Nude Character" feature will remain active for 3DXChange Pro users as it has in previous versions. Whereas the FBX or alembic export will require the Pipeline version.
