By kamal_sadanah - 8 Years Ago
Hi, Everyone, I'm trying to import a video sequence as a plane (it works fine). When i try to add an opacity video its gives me a codex error. Need Help
By Kelleytoons - 8 Years Ago
Not all formats are recognized and in particular things with alpha channels need to be VERY specific formats for iClone (which is why I bought PopVideo to do conversions).
When you load in a Popvideo it automatically loads in both the diffuse and alpha channels. Otherwise you can create an alpha with a grayscale image but, again, not all formats will work. It's further complicated by the fact you can't rely upon the extension (formats like AVI for example are catchalls for a wide variety of codecs). In general I've found iClone to be pretty picky about things which is why I finally gave up and got Popvideo.
If you list your format and what you used to produce it perhaps others can help you further.
By mtakerkart - 8 Years Ago
May this post could helps you:
https://forum.reallusion.com/FindPost322216.aspx
