Scaling a character created in CC
https://forum.reallusion.com/Topic327865.aspx
Print Topic | Close Window
By bruceberg - 8 Years Ago
Is there a quick way to scale a character created in CC. I'm creating an entire crew of a spaceship all wearing the same uniform, so I just popped a different head I created in CrazyTalk onto an existing Body in CC. I would like to scale the resultant body in either CC or iClone to make everything from a young boy to a tall man. (These are all my actual family members) But the scale feature is ghosted in both CC and iClone for the characters I created. Hopefully There's an easier way than resizing each body part separately in CC. I appreciate any tips, as always!
Regards...Bruce
By Postfrosch - 8 Years Ago
Hi Bruce
https://forum.reallusion.com/uploads/images/c27ff426-4bd3-49a3-ac0f-250d.jpg
Greets from Germany
Postfrosch
By Lord Ashes - 8 Years Ago
If you don't have Essential Pack it should be fairly simple to create a Height morph.
1. Load basic CC character.
2. Use the Reset button to get a neutral CC character.
3. Export Nude Character.
4. Open in Blender (or similar software)
5. Scale height. You can play with scaling the other dimensions a bit and I excluded the face...but in your case you don't care because you are replacing the face.
6. Save as OBJ with a different name.
7. In CC create a new Morph Slider. Use the CC neutral character as the source and the modified version as the morph.
By woody173 - 6 Years Ago
I went absolutely ballistic about this very subject a couple of years back. Every software i have ever used as three fundamental actions, Rotate, move and scale. Reallusion just leave these little things out just to get more money out of you by forcing you to purchase other software or addons. Unfortunately i felt my comments were just ignored and I ended up in paying yet more money for the essentials pack.
I hope you sorted it out using blender, but that to me is just another piece of software you have to learn to do a relatively simple task
Best of luck
Woody
By Rampa - 6 Years Ago
Easiest way is to use the scale function in the iClone Modify panel.
https://forum.reallusion.com/uploads/images/8917cc49-93c1-4a87-8b99-bd4c.jpg
By charly Rama - 6 Years Ago
Rampa, thank you. I use more complicated function, but this function was there, near, and I complicated myself my life by other ways. You saved my life more than one time, be blessed Rampa :)
By diomkal - 6 Years Ago
Thank you Rampa, I have also searched.
Rampa, as you can see, I do not have this option on my Iclone interface:
https://forum.reallusion.com/uploads/images/c87d5cab-465c-4985-8d64-41ba.jpg
By Postfrosch - 6 Years Ago
Hi Diomkal,
I see on your picture that you use IClone 6pro.
The body scale feature that Dir Rampa proposes
But there are only from IClone 7.xx. You can not have them therefore.
Greets from Germany
Postfrosch
Danke schön!! :)
