Cant get the eyelashes to appear in Blender
https://forum.reallusion.com/Topic327101.aspx
Print Topic | Close Window
By AasmundSchei - 9 Years Ago
I cant get the eyelashes to appear in Blender after I have exported the character from Character Creator.
Im no expert in Blender at all, but I tried different shadermodes with no luck. What do I do wrong?
By Rampa - 9 Years Ago
Texturing in Blender is a bit of a pain. But you don't actually need the textures to show, as long as the eyelashes are there. The character is only a vehicle for importing clothing, or tricksy bone-morphs. You should just delete that character as soon as you save your clothing to your library in CC. That is RL's recommended work-flow.
But try this:
https://forum.reallusion.com/uploads/images/5e670b7b-ba0a-401b-9463-6634.jpg
Yes, Im saving up to a new pc, so therefore I cant use Maya right now :P So the eyelashes will appear as they should in other applications? I did try texture mode, material mode and rendermode but it wont show up.
Try this.
click on the tiny arrow that makes the right-hand panel pop-out.
Find the "Shading" header.
Click on the drop-down menu that is labeled "multitexture".
Change it to "GLSL".
https://forum.reallusion.com/uploads/images/9d0879ea-fc07-46d0-8cfe-03ba.jpg
https://forum.reallusion.com/uploads/images/a229aca0-84c8-4e49-9489-4b0d.jpg
I work in Cycles so I dont have the GLSL mode. It appears in Blender render but then my textures wont show up. What can I do then?
I'm useless at that point. Sorry. ;)
Aight, thanks for your help anyway :)
By jbiziou - 6 Years Ago
I got the eyelashes to work in Blender Eevee and Cycles,
I had the same issue, they came in opaque.   This was the hint.
You need to change the Eyelash material to Alpha Blend.  By default it comes in as opaque.
Hope this helps :)
~ Jourdan ~
By illusionLAB - 6 Years Ago
https://forum.reallusion.com/uploads/images/7744ebe9-6861-432a-8caa-c108.jpg
