v3.12 (3.12.1719.1) released on May 24th, 2017
Several new functions added, features enhanced, and bugs fixed.
1) Function and Content Enhanced:
Enhanced: Allow use "Add Bone" function to connected existed bone.
2) Bug Fixed:
Fixed: Possible program crashes when replacing the G3 character which with Morph Head.
Fixed: Failed to read the naming of Image Layer from PSD file, which with the same naming.
Fixed: Possible program crashes when using hotkey to delete "Thigh" bone on G3 character.
Fixed: Partial Update is disabled when updating Free Bone character from a PSD file.
Fixed: Image quality degrades when saving or performing undo/redo functions.
Fixed: Attached button function does not work when the target is a body. Feedback Tracker
Fixed: Launch to External Editor does not work correctly on Morph-based Head. Feedback Tracker
Fixed: Inconsistent positioning of the pupils (eyes) between the PSD file and CrazyTalk Animator.
Know Issue: Character not display completed once the image was separated into multiple parts in psd file.
v3.11 (3.11.1625.1) released on April 27th, 2017
Added: Supports PSD templates for creating Props. Pipeline Version Only.
Enhanced: Supports PSD files without group folders for creating Free Bone characters.
2) Bug Fixed:
Fixed: Abnormal Render Style panel after creating sprite-based head for non-standarad characters.
Fixed: Render Style malfunction when sprites are changed for PSD characters.
Fixed: When the Invert option is turned on/off, the color for G3 body (Saturation profile) is inconsistent.
Fixed: Hair disappears when a new head is applied to character in the Stage Mode.
Fixed: Accessories can't be attached to a target facial feature by clicking on the Attach button.
Fixed: Default color changes for characters and props executed twice when toggling Render Style command.
Fixed: Possible Program crashes when manually adjusting character bones in the Composer Mode.
Fixed: Mesh was too low in character's mouth, when created from a PSD file.
Fixed: Program crashes when using Invert function in Mask Editor and then closing the Mask Editor dialog.
Fixed: Possible program crashes when switching character when using Face Key Editor.
Fixed: Failed to Import PSD files which included extra image layers.
Fixed: Possible Program crashes when replacing second G3 character created from a PSD file. Feedback Tracker
Fixed: No response for Hue adjustments in Render Style. Feedback Tracker
Fixed: Render Style does not support multiple selected objects.
