Crazytalk 8 pipeline -> Character Creator 2 Failed launch
https://forum.reallusion.com/Topic326611.aspx
Print Topic | Close Window
By hcameron90 - 9 Years Ago
Ok for some reason I can't export my Crazytalk heads to CC2 I had Character Creator 1 but lost everything on my computer.
Now only Character Creator is available but when I export my heads to Character Creator a message says
"Failed launch, please make sure your using
Character Creator 1.3 or above. But im using Character Creator2?
Do I have to change my preferences to fix this??
Please help!
By duchess110 - 9 Years Ago
hcameron90 (5/24/2017)
Please help!
This seems to be an issue at the moment exporting heads from Crazytalk Pipeline into CC2.
I refer to this thread that grabiller started, and our workaround to get them into CC2
https://forum.reallusion.com/326141/CT8-Calls-CC15-Instead-Of-Latest-CC-Installed-Version#bm326149
By animagic - 9 Years Ago
To summarize the workaround, what you do first is export the head from CC (File => Export or Ctrl+Shift+H). This will give you an RLHead file.
You can then drag/drop the RLHead on your CC character to apply it.
