Reece_whittingham (5/23/2017)
centimeters are what i would work in anyway, thanks for the heads up though. I know the sliders go between -100 and 100. Knowing this would there be any possible way to link between centimeters and the slider scale? for example if i moved a morph slider up by 10 would that correlate to a 1 centimeter increase in size? if so it could be possible to work out what dimensions each body part would be.
I believe this is a simple math problem. If, in your morph, your points move over 100 units (1m), then moving the morph slider to a value of 1 would means your points have moved 1 unit, that means 1 cm.
