When I open facefilter, it's a small window and nothing works, have to go in task manager to close
https://forum.reallusion.com/Topic326201.aspx
Print Topic | Close Window
By audwire - 8 Years Ago
When I open Facefilter Pro 3, it's a small window and nothing works, have to go in task manager to close. Paintshop pro x9 works fine but it's 64 bit. Do I have a setting in facefilter wrong? if so, can I do?  OK silly me I need to put an extra pair of glasses to see the small writing. Now new problem, the window opens but all the word and characters are small and squished together, can't read them.
By gcshep - 8 Years Ago
Hi I have just opened my copy on a laptop and it works just fine have you tried a uninstall and then a reinstall.
Best Regards
George
By Pete_RL - 8 Years Ago
audwire (5/17/2017)
Are you maximising the FaceFilter window to full screen? This will normally resolve the problem of overlapping text.
Also what display resolution are you using? FaceFilter is not optimised for 4K or other Ultra HD screens so text will look tiny if you are using a 4K resolution. A resolution of 1920 x 1080 is probably the best to use for FaceFilter 3.
That worked, changing the screen setting 1920 x1080 solved the problem, I did have to close everything and restart the computer, thanks, I have spent 3 days trying to figure it out, I did change the resolution but I didn't restart, Problem Solved, Thank you very much, now I can start working on the project I bought the program for, again thank you.
