By Dragonskunk - 8 Years Ago
I wish someone would share a trick, a way, to open two 3DX at once. Why? Often I add new sliders (deformers) for the Expression Editor to a character. But you get an error message if you try to open saved values of the original character with a different amount of adjustments. I thought a solution would be to transfer values quickly between both old and new using cut and paste of values with 2 3DX open at the same time.
By planetstardragon - 8 Years Ago
v5 + v6
By wendyluvscatz - 8 Years Ago
yeah I use 3dx5 mostly to import my FBX files simply for the wider compatibility and ability to have 6 open as well and work between the two on FBX import exports. I can this way make my CC characters props with perform motions too.
Thanks for the advice guys.
