CC MALE BODYSUIT
This
tight-fitting bodysuit cloth has easy-to-edit texture mapping. You can use the traditional textures in the Modify Panel to launch & edit each map; or launch the UV reference and create your own maps. Use the Appearance Editor to quickly make changes to texture/color of the fabric & create an outfit in mere minutes.
If you want to be really ambitious, then use the UV reference to create your own RGB map to use in the Appearance Editor for a multitude of options!
The outfits in the promotional images below were created in CC in less than 2 minutes each by simply moving sliders in the Appearance Editor.
Get the pack HERE
