By galgammer - 9 Years Ago
I installed and used the demo successfully bringing characters from Character Creator over to iClone. After I purchased & installed the iClone 6 Pro version, the "send character to iClone" is missing - no icon. There is no choice in the File Menu->Export either. How do I bring my character over to iClone?
Thanks!
By mtakerkart - 9 Years Ago
Yes they changed the UI. Click the icon "Export as I.avatar" then drag and drop your character in the Iclone window. Or File/export/I.avatar.
Thanks. I did try that, but I get an error that says "fail to load file" when in iClone importing the i.Avatar. I also tried dragging/dropping and received the same error. I exported the character with settings for: Character Creator 2.0 for iClone & iClone 7.0.
I'm using Character Creator 2.0 and iClone v6.53.
By Rampa - 9 Years Ago
You need to save your CC as 6.5 for iClone 6.53.
Ok. That worked. Thank you!!
By dbshaffer - 9 Years Ago
I tried this as well, was able to export 2.0 CC characters into iClone 6.5. I have the Assassin Playset, I cannot export into iClone6
1) saving as 2.0 and iclone i get "failure to load" error 2) saving as cc1.5/6.5 I get "exporting error"
All of my iclone is up to date. iClone 6, 3Dxchange, and CC 2.0. Any suggestions?
