By srjones98 - 9 Years Ago
For some reason the Create New actor is not working correctly. It will show it is uploading the photo and nothing. The image processing window, auto-fill anchor points and so on do not come up. Anytime I click it just make the error noise. I tried restarting my computer and that didn't work. I also uninstaller the program and reinstalled it to see if that would help but it didnt. I have several items I need to have animated by this Friday. Does anyone have any ideas of why this isn't working? Thank you
By animagic - 9 Years Ago
What product is this about?
It is for Crazytalk 8- standard
Here is a link to a video of what I am talking about. If you have ideas please let me know. https://youtu.be/xLf2xNGSbh0
I have Pro, but the windows to create 2D heads comes up in my case, so I don't know what the problem could be.
The only thing I can thing of is the window is somehow hidden behind the main window.
Try this: resize the main CT8 window to less the full screen (just enough to see the create face icon) and repeat what you did before. Hopefully the window will now be visible.
Thank you for your feedback. Darn it didn't work. It is so odd it worked perfect before. Thank you for your feedback I appreciate it. I am under a time crunch and I am not going to make it at this rate.
As this seems specific to your system, you could try Support: https://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx.
What is your OS? If it is Windows 10, then a recent update may have caused problems. One area to check is your graphics drivers.
By Snarp Farkle - 9 Years Ago
Hi srjones98,
It sounds more like a corrupt jpg to me, is the size about the same as the pig, pixel wise? If it's a really large pic that may cause CT8 to hang, or a raw pic from a camera not converted quite right has given me problems in the past.
You could try saving the jpg as a png through your favorite image editor and give that a shot, or maybe saving it again as a jpg might work also. If you post the pic in question I would give it a try in my pipeline version to see it it hangs for me too.
Thank you for all your help. I deleted it off my computer and install it on my desktop at home. It is working fine on my desktop. Not sure what the deal was with my laptop which is my computer I use for all my graphics and video. I will just finish my project on the desktop. Thanks again
