Picture layer and change of edit mesh mode grid color
https://forum.reallusion.com/Topic323373.aspx
Print Topic | Close Window
By ThomCromer - 8 Years Ago
Hi,
I'd like to have the possibility of putting a picture (of a face e.g.) in front of the working area (as a layer with variable transparency). It would really help with faces and proportions.
And I'd also like to know if I can change the color/transparency of the mesh editing grid. These white lines are annoying...
Thanks,
Thom
By animagic - 8 Years Ago
ThomCromer (4/18/2017)
Hi,
Thanks,
Thom
You can change the grid color in Preferences.
There is a free tool that will give you an image overlay: https://imageoverlayutility.bitbucket.io/. Works quite well.
Hi and thanks for the reply.
I will try the free tool, good tipp!
But the grid color in Preferences is only referring to the world grid - not to the mesh mode...
ThomCromer (4/19/2017)
I'm sorry, I should read better...:blush:
I agree, it is kind of bright. I'm sure a setting could be added. It might be worth to enter it as a suggestion in Feedback Tracker.
No problem. And thanks again!
