Text Animation in CTA3
https://forum.reallusion.com/Topic323221.aspx
Print Topic | Close Window
By Snarp Farkle - 4 Years Ago
K.M. (4/17/2017)
OK got it, thanks for your help. Although it's doable the way you described, I was hoping to change the fonts, text size, fill patterns etc. on the fly. By creating external props, I will have to create many props of varying text properties to use them when I need them. Buy any ways, I might use another program to add text on top of the video output from CTA3. Thanks again for your tips, SF.
I was able to simulate typing while playing around in CTA3, if you're still interested in doing it.
By K.M. - 4 Years Ago
Thanks again. I will have to play with CTA3 to learn the tricks. But generally I know how to do the text simulation. It would work for me if I have only 2 to 3 text messages in the video. If I have more than that, then it will be somewhat messy. I will try it out in my spare time. Cheers!
How do I animate text in CTA3? I noticed that CTA3 has very limited text templates. I know that there are elastic motion animations available. I want to be able to write text like typewriter, one character at a time. Or use mixed colors, fonts, sizes and pop them on screen using the elastic motions. I need a link, a video or some examples to see visually so I can use them in my own future videos. Thanks for your help.
K.M. (4/16/2017)
Yes it can be done, you will need an image editor such as PhotoShop, Gimp or PaintDOTNet which is the one I use.
I didn't spend a lot of time on this but wanted to prove that it can be done.
1) Create the letters you want to animate and save each one out as a png file.
2) In CTA3 create a prop and select the first letter, animate it then repeat for the remainder letters to animate.
The page about creating props in CTA3 is [HERE]
