Where is the beard settings?
https://forum.reallusion.com/Topic320527.aspx
Print Topic | Close Window
By Kelleytoons - 9 Years Ago
Okay, so perhaps I've been away from CC for too long, but I used to be able to find the settings for the various beards in the textures and in CC2.0 I don't see anything resembling this.
I tried selected the head and loading the appearance editor in, but I get nothing on the screen then to adjust.  So I must just be missing a step.  Any help?
By nlprod1 - 9 Years Ago
Under Appearance go to Skin_Head. its found in the Hair sub layer.
By Rampa - 9 Years Ago
navigating has gotten a bit more complex. It is much easier if you use both columns, and have the "Show Sub Items" box checked. You will need to select a catagory in the left column, and then actually open that category in the right.
https://forum.reallusion.com/uploads/images/8e3f073f-bb48-4dd6-b12a-3d0e.jpg
Yeah, it was the navigating that was throwing me off -- what a PITA to always have to expand the selection (why else would you select something on the left if you did NOT want to expand it?).
Thanks -- got there.
